Mounting to engine stand
Big Josh
I am currently working on a 3.0-4.0 engine swap and had a question about mounting the engine to a stand.
Does anyone know what size bolts I should buy to attach my 1992 4.0ohv engine to an engine stand?
It is hard to say because not all engine stands have pegs of the same length. I take one bell bolt and the mounting head to the hardware store and get bolts that match the threads of the original and about 3/8 inch longer than my pegs.
Big Josh
My bad; I should have better explained my need. I was hoping to get the thread size as I can measure my stand and add 1/2 inch or so. I can use washers as spacers so the length doesn't need to be exact.
Does anyone know the thread size; is it metric or SAE?
alwaysFlOoReD
5,129
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It will be metric. My GUESS is m12. Take a bolt with you....
lil_Blue_Ford
6,209
Butler, PA, USSA
4.9L
It’s metric. Pretty sure it’s M12 coarse thread
Sent from my kite using a trebuchet
It is metric, I don't remember the size or pitch, but there is a reason I told you to take a bell bolt with you when you go to the store.
Big Josh
Thanks for all the responses; it is actually M10x1.25.
Big Josh
Correction it is 100% M10X1.50. Good thing I bought both M10X1.25 and M10X1.50 because my information was incorrect. Thanks for all your help the engine is resting nicely on the stand.
