Mountaineer 302 to 4spd w/od manual mating
Hoonatic
Kentucky
Hoon 4 life
OK title explains it all.... I have a 95 ranger XLT 4x4 4.0 V6 4spd manual w/OD and I'm not sure what year Mountaineer it is because I haven't laid eyes on it, but it has the 302 and it is the full engine with wiring harness and ECU, so I guess my question is will that 302 mate with my 4 Speed transmission?
Mac
183
C. Wisconsin
2000
199
No, not without an expensive adapter. Even then not worth the trouble. V8 has too much power for stock Ranger trans.
Dave
And that isn't a four speed transmission. It's a five speed.
Four speed over drive is four forward gears, the last of which having a ration of higher than 1:1.
A five speed trans has five forward gears. Last time I checked OD is a forward gear (unless we are talking about something really bad-ass).
Hoonatic
Kentucky
Hoon 4 life
Well it seemed like a 4 speed with OD cause the 5th gear doesn't seem to make a big difference in ratio, so I assumed it was a 4 speed w/OD.... Thanks for the info.....
scott9
You'll want a 5 speed from an f150 from 1990 to 1996 , it will have the correct bellhousing bolt pattern for the 302, both v8s and the inline 6 have the same bolt pattern so a trans from any of them will work.
Sent from my SM-G930V using Tapatalk
