Motor Mounts
ATX
11/2014 MTOTM Winner
MTOTM Winner
Austin tx
Built not bought
For my 94 swap I used the stock 4.0 mounts and explorer 5.0 plates flipped side for side plates wise . I went this route since mounts are easily replaceable with over the counter parts .
I have since changed the passenger side mount to a 85 bronco mount and custom mount bracket on the frame .sliding is pretty hard on thAt one mount I found out .
bergilong
I should probably also mention that I have a 2.3.
ATX
MTOTM Winner
Austin tx
Built not bought
Well don't know if the mounting locations are the same on the frame
Between 4 and 6 bangers . But I'm pretty sure the holes are there and just not used . So with that you could probably still buy the 4.0 mounts cheap at autozone or wherever and get the block to mounts plates
BlackBII
Ranger Custom
Truck of Month
982
UT
The crossmember has the holes for the 2.3 and the 4.0 mounts, so you should be good. :icon_thumby:
