Motor mounts and frame similarity?
AKjeff
SE Alaska
I have this 4 cylinder turbo diesel from a '85 Dodge D50 (Mitsubishi). From everything I can find online it is the same engine Ford used in the Rangers from '85 to '87.
My question is, will motor mounts from a late '80's Ranger bolt to the frame rails of a '93? Are the frames the same width? I figured others may have run into this while swapping motors between the different generations of Ranger.
Thanks
alaskan155
6
washington
FORD
7.3l/4.0l
as long as you match 4x4 to 4x4 and 2wd to 2wd the crossmembers from gen 1 to gen 3 are the same
