Alberta 7.3
- Jul 28, 2015
- Reaction score
- 0
- Make / Model
- Ranger
- Manual
Bought a set of Morimoto XB LED fog lights to replace my beat up old OE units. Eventually I will do HID projector headlights so light colors match.
Installation time: 15-20 minutes
Difficulty: 2/10
The old lamps
Disconnect the bulb connector, and using a 11mm-7/16" socket and ratchet, remove the 3 stamped nut from the backside of the bumper. Pull the light from the bumper. Measure and note the length of the adjustment screw to one of the mounting studs, this will help you get the new light aim close to the original. Remove the adjuster screw and spring. Carefully pry the base/bracket from the old light lens/reflector. With the fog lights switched on, plug the leads of the new lamp into the harness connector. If it doesn't light, reverse the connections and try again. Note the polarity and plug the leads into the supplied connector shell. Snap the new lens/reflector into the original bracket and install adjuster screw/spring/plastic nut. Adjust screw to earlier noted measurement.
Re-install the lamp assembly and connect wiring. Use zipties to secure wiring as required. Make final aiming adjustments.
Comparison of old and new lights
Complete
Difficulty: 2/10
The old lamps
Complete
