Autofab has a great kit. The middle of the road d35 is low bling, but really works good. Its capable of 16inches of travel.It's stock width, and will help keep the over all price down.and best of all for a daily driver is alighnes great.
If you think you need more than the autofab kit, I would suggest caging the truck first.one for safety, two, tall coilover mounts really start taxing the frame with out the frame being tied up in a full cage tip to tip.
Dave at threatmotorsports also dose some good work at really good prices if you want extend and coil overs.Just rember with extend, comes extend axle shafts$300 on the cheap,and fiber glass fenders.300 avg, and then coil overs about 600 over smooth bodys,and a motor cage 500-1000...adds up quick to do it right.
Dont forget to save/have some money for the rear if you plan on really playing at speed.
you have many choices here,the giant 64 inch kit is proably one of the best leaf set up out there, but it also cost.
there are a few diffrent packs from deaver, there is the autofab 2link set up that uses autofab spec national springs, or you can also go direct to national spring for one of thier leaf packs.
the hart of everyting is going to boil down to shocks. for a budget build daily driver, FOA shocks would work great.
just keep this in mind when picking your parts. your shocks are going to be the hart, the suspention is going to be the soul, and if your not carefull when all done, the cage is going to be your ass if you push it to hard.
and most of all, think it over , over all. can you afford it, will you finish it, alot of people get the full tilt boogie kits for the front, but never get to enjoy them cause they blew everything on the front.
in other words unless your rich, stick with something like the autofab middle of the road kit.and keep it simple.....
just so you can get a ideal of the autofab stuff, here is steveG's fullsize bronco, 16inches of travel...
http://www.youtube.com/user/steveG23
he use to post here, maybe he still lurks?
