Maybe wrong fluid
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
My neighbor used Valvoline Maxlife multi vehicle transmission fluid in his transfer case in a 2004 ranger ,it says Dex/Merc and mercon V along with a bunch of other vehicle manufacturers , question is will this fluid trash his transfer case. I told him that I use Dex/Merc in my 2004 and 1994 and that I would ask you guys . He needs to join the forum .
Its fine. That's no longer the correct fluid, but when the truck was built it was. The spec was updated to "transfer case fluid" a few years after the truck was built, which is Merc V with some other additives to help the magnetic clutch.
Dangerrangers
Ohio
94 and 04
4.0 s
So should we both be using transfer case fluid from Ford ,changing over to Ford transfer case fluid would be fine with me if that's what I should use .The Maxlife is the full synthetic in the red bottle. I'll let him know . Thanks
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Dex/Merc is 100% the correct fluid. Mercon is what the truck was originally spec'ed for, and is now called "Dex/Merc" only because of some crap Ford pulled with licensing of the Mercon name a number of years ago. The fluid itself has not changed.
Straight Mercon V normally shouldn't trash anything in the t-case either, but like adsm mentions, it can potentially cause a lag with the spin-up clutch used in pre-'01 cases (and for similar reasons is why I do not recommend Merc V in the M5OD). However unless you have a pre-'01 truck and often shift into 4x4 from 2WD while speeding down the road, it's a non-issue ('01+ trucks don't have a spin-up clutch since the front end is already spinning 100% of the time).
Dangerrangers
Ohio
94 and 04
4.0 s
Thanks Guys....
Fordfreak11
Ford ranger
I need help!
Please help me I'm new and can't figure out how to post something to have all you help me fix my for our tell me what I am doing wrong. Thanks. Much appreciated
Dangerrangers
Ohio
94 and 04
4.0 s
Are you ****ing shitting me ! Post under the forum page that pertains to your needs and you will get an answer !
No members online now.
