Manual hub rattle
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
So I’ve been chasing a rattle in the front end of my truck for a couple months or so. It happens when I hit small bumps, cracks in the black top or go down a rough road. Almost sounds like a loose washer on a bolt. The driver side always rattled more than the passenger side but both do it.
Today I decided to pull the front wheels off and poke around again, mostly looking for anything that might rattle. To no avail, I decided to pull the hubs off and clean them since they were pretty filthy inside (grease). Come to find out, I have a Warn 29071 hub on the drivers side and a Mile Marker 428 on the passenger side. I could make both rattle just shaking them with my hands but the Warn was by far worse. So I disassembled both and cleaned them up. When I took the Warn apart, it had much less grease in it and the bearing was completely dry. I cleaned the bearing out and lightly packed it with wheel bearing grease and applied a light film of very thin marine grade grease to any sliding surfaces. Reassembled and I can’t make it rattle anymore.
The Mile Marker hub was packed full of some generic looking brown grease and has a bushing in it instead of a bearing. It got the same treatment as the Warn hub but this one still rattles, just not as bad as before. Is this a common issue with this style of hub? I’m assuming the gear that slides in to engage the hub when you turn the knobs are what rattles. Is there any cure for this? I put a very minimal amount of grease back in. Just enough to keep the cheap plastic cam from chewing the three teeth off of the engagement disc.
Thanks for any and all input.
Rick
planeflyer21
19
Sonoran Desert
I am guessing you checked when you pulled the wheel but I just had to tighten up my caliper mounting bolts on the passenger side.
This was right after replacing them, so I probably didn't torque them down.
Like you said though, every little bump. Quite irritating.
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
Brakes are good front and rear. I’ve had them apart a couple times now. First thought was the anti rattle clips were gone but they’re there and in good shape. The Mile Marker hub didn’t start rattling until I locked the hubs in and beat on the truck a little bit.
Ewgoetz
Venice, Florida
The locking hubs shouldn’t be packed with grease, they should be dry with a light coat of grease on the moving parts.
Sounds like the previous owner might of went junkyard shopping for the hubs. You might have worn out parts in them if the rattles are that noticeable.
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
You’re right on all of the above. The Mile Marker hub had some jy markings on it. The Warn hub was actually worse for wear. It rattles so loud it sounds like I have the dang liberty bell bolted to the end of the driver side beam.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I have the rugged ridge hubs. I made the mistake of putting some grease in them. All they did was hang up. I cleaned all the grease out and shot a bunch of tri-flow silicone lubricant in them and they have worked flawlessly ever since.
DRanger024
Ham Radio Operator
487
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
We’ll see what happens come winter. So far, no problems but I’m sure I’ll be kicking myself when the hubs have to come off in single digit weather.
