eightynine4x4
- Oct 15, 2020
- Reaction score
- 178
- Location
- New York
- Make / Model
- Ford Ranger
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
So, yeah, all 4 of my bearing lock nuts, 2 on each side, are loose enough to spin by hand.
How about that!
Referred to shop manual, found the bearing adjustment procedure, and am about to go attempt to locate a 4 prong spindle socket that’s the correct size. Somewhere around 56 mm outer diameter.
Also both of my inner brake pads had no anti vibration clips installed. I just finished redoing the front brakes, so everything is back to good standing now, including the caliper pins.
The more i open up this truck, the more I realize i should have flown off a cliff by this point.
How about that!
