Dustincoc
- Sep 4, 2012
- 0
- Canton-Potsdam Area, NY
- Ford
- Engine Size
- 2.9l
Went out to work on the core support I'm fabing for the Ranger and after tinkering with the welder for a while was laying some decent beads so I ground off the welds(my father said they looked like bird sh1t) I'd put on the piece before and was going to get some better welds on there. I know I'm getting at least decent penetration because I melted the corner off one of the 1/8"x1" and 1 1/2" angle iron pieces I was welding. Biggest help were switching to a .035 tip running .030 wire even though the .035 tips are for Miller welders and I need Tweco/Lincoln tips for the welder I'm using. Didn't even know I had them till I found the pack on the garage floor the other day. Also took off the noozle since I'm using flux-core and read somewhere its not really needed and improves visability with it gone. Still having some sort of wire feed problem, the wire has some sort of pause every little bit for half a second or so and messes up the weld. I figured its something to do with the liner but both .035 and .030 wire do the same, I'd expect the larger wire to jam up worse if there was something in the liner. 3 different spools do the same thing so its not the wire and it doesn't seem to jamb when the tip is off but I've switched tips many times and every one does the same thing no matter the size. I may have the spool too tight but I really can't have it any looser since the retainer is barely on as it is. Another problem I keep having is that I can lay a great bead right next to where I'm trying to when I get off track, but the weld is horrible if I get it where I want to.
As far as progress goes, I managed to break one of the welds I'd just rewelded just as it was getting dark so I didn't get it back together so essentially I made negative progress today. I did get the birdsh1t weld ground out of the inside of the one piece of angle once it was apart which I couldn't do when it was together. I also managed to burn myself twice on freshly welded metal as I repositioned the piece for the next welds.
Welder is a 2 year old Jobsmart MIG 125 that I barely used since I finished the project I bought it for 2 years ago. It seemed to lay decent welds then although I can't look at them now. I was welding a truck frame then and managed to break on the other framerail in the same place a week after I got that one fixed and all the brake and fuel lines ran right past the second crack so I'd have had to replumb both brakes and fuel had I fixed it. It was a '95 Nissan Hardbody and the repair I did to the frame was the third one and I needed at least 2 more patches. The frame was fixed once before I got it and I had another crack fixed after I had the truck for a few months. I think I hd the truck a total of 6 months before I junked it. I was happy with the welds I got then and that was the first time I'd used flux-core(I was used to MIG and those nice looking welds) I was happy with there appearance so They must have been close to MIG looking welds.
