mack4
mack4
Does anyone know where I can get an original BUILD SHEET for my 2002 Ford Explorer? Is there a place in the vehicle where I can look at the BUILD SHEEt?
3,614
Pull up the carpet in the passenger's foot well. Sometimes they get left under there. You can also call Ford, they keep them on file.
If you give me the VIN I can get you something that is close to the build sheet. It tells you engine, trans, color, gears and such, but not some of the other things like sun-roof or heated mirrors.
JoshT
1,877
Macon/Fort Valley, GA
I know in older vehicles they would put the in the bottom of the seat. I highly doubt that they do that anymore though. There used to contact info floating around the net for a department at Ford which would provide them for a small fee. Never bothered remembering or bookmarking it though, because IMO they are really only useful for restoration purposes. I don't intend to leave anything I build stock so I don't care about what it came with from the factory.
3,614
I know they still put them under the carpets because I just found one this summer on a 2011. The H-valve for the A/C gave out and we could only get it with a new condenser (parts availability issues) so I had the whole interior of the truck out. Found it when I pulled up the carpet to reposition the floor ducts.
JoshT
1,877
Sorry I was typing my reply same time as you were, didn't see your post till after I hit submit. Wasn't questioning your reply in the slightest.
mack4
Hi: This is mack4. my VIN # is: 1FMZU74WX2UA57252 Thanks
3,614
Pretty run of the mill Explorer:
VEHICLE DESCRIPTION: 2002 EXPLORER 4DR BODY STYLE: 4 DR EDDIE BAUER 4X4 ENGINE: 4.6L SOHC (ROMEO)
TRANSMISSION: 5R55W AUTOMATIC AXLE CODE: D4 ENGINE CALIBRATION: 1U51A50A
PAINT COLOR: OXFORD WHITE SOLID C/C PAINT CODE: YZ RADIO: AM/FM STRO/CD CHANGER/CLK
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 7.0 X 16" 5 SPOKE CHROME WHLS FRONT TIRE: P245/70R-16 OWL A-S
GROSS VEHICLE WEIGHT: 5840 LB. GVW
