steveoelo
Mighty Canuck
- Mar 26, 2016
- 0
- Ford
- Engine Size
- 2.9
Recently swapped my noisy fm132 with a m50d that the guy was unsure of the condition. Opened it up and everything inside looked brand new. Installing it, when putting the fluid in, I noticed metal shavings on the magnetic drain plug. Took it around the block and noticed that 3rd, 4th and 5th made noise but only at certain RPMs. For example anything above 2500rpm in 3rd makes no noise. Anyone know what it could be or am I just hearing engine noise? I figure if it's a bearing it will make noise at any speed in any gear expect 4th, but 4th seems the loudest. The noise kinda sounds like a grinding noise but every gear shifts smoothly. Thanks
