- Nov 6, 2008
- Reaction score
- 16
- Location
- Federal Heights, Colorado
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- Automatic
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- ~10
- Tire Size
- 35
Hey guys and girls,
I'm getting trouble codes p0171 and p0174. I have a Jet power programmer which lets me look at simple diagnosing numbers. The long term fuel trim is holding steady at 25% on both banks. Both O2 sensors seem to be working fine, the MAF sensor seems to be clean. I ran some vacuum tests starting with spraying starter fluid around with no noticable change. I did find a small vacuum line fitting that was cracked and replaced it.
I recently tore down the engine before all this mess to replace the valve seals. The Fel-pro gasket kit I got came with the two piece lower intake manifold gasket. I ran a bead of sealant on the surface area of the block between the two gaskets. A smoke test showed smoke coming out basically in that area in the front.
After taking off the lower intake I noticed that the sealant was still on the block side, the intake side was clean. Like the sealant hadn't adhered to it.
This long-winded explanation leads me to my questions: 1) did I put sealant in the right area? 2) did I use enough sealant? (How much should I use?) 3) is there a sealant you recommend for this application?
Thanks in advance,
Stay safe,
Wash your hands,
Eric
P.S. if pictures will help, let me know.
Thanks in advance,
Stay safe,
Wash your hands,
Eric
