oachs83
- Sep 23, 2009
- 1
- Minnesota
- Ford
- Engine Size
- 3.0
I have a 02 ranger automatic 4spd 4x4 that has 187,000 on it. It will shift hard unless you are real easy on it. I flushed the tranmission because it needed it. When I hooked it up to the machine at idle the pressure gauge barely moved and was not pushing fluid out very fast. If I gave it gas the pressure gauge shot up around 15 -20 psi or so. Back at idle barely 1 psi. Does this mean I need a filter change? After the flush the first 5 miles or so it shifted very smoothly and the kickdown around 50mph was smooth. After that I tried the kickdown again and it started to shift hard again unless I am real easy on the gas. Anyone else have a similar issue or fix?
