low budget prerunner project
rangerdanger208
Idaho Falls, ID
sorry I forgot to answer your question in my last post I haven't done anything with the bump stops. just started bending up a spare tire carrier today!! im trying to come up with a way to build a hinge so I can drop the carrier to load a bike.... any ideas? was also trying to come up with extended radius arm designs I think im going to stretch them back to the tranny mount???
upnsmoke
9
baltimore, md
2.0
That's good that it rides nice. I do like Rancho shocks. They are on my truck currently. If I were you though, I would be worried about bottoming a shock out and damaging it or bending a shock mount. I jacked my truck up and took a spring out with the shock installed and pushed the arm up until the shock bottomed out. There was some room between the arm and the bump stop, which means I would have eventually bottomed the shock, especially when I did some off roading. All I did to fix it was bolt a piece of 2x2 square steel to the frame and the bump stop to that. It's not pretty, but it's good enough for temporary.
I eventually want extended radius arms myself. There are some good designs here on the forum that have given me good ideas for mine. I have radius arms from Autfab's econo lift right now, which mount to the stock location and are modified to have correct caster with a 4 inch lift. I have been eyeing hinged tire carriers and tire gates and the like, too. I'm sure someone has done something you could get some ideas from. What do you have for a bender?
rangerdanger208
Idaho Falls, ID
look up thc-fab on you tube this dude has a sweet design on his carrier. its the only video I can find with a flip down carrier
rangerdanger208
Idaho Falls, ID
so I was having a couple issues... my truck would die every time I hit a bump or crack in the road. I was scratching my head about this for months! turns out it was a loose connection on my ecc relay. I posted the issue in the v6 thread on here and had not a single reply!!! anyways I fixed it. then I had a weird sound like a freewheel on a bmx bike coming from the front when I would turn left. turns out it was a clip that popped off on the inside of the hub lock.
rangerdanger208
Idaho Falls, ID
I started putting together a spare carrier.
RollinWOT
10
Cochise County
Ford/Kia
3.0L Vulcan/GDI 2.0L
Looks good so far man, keep up the good work and updates!
86MUDRCJ
8
Sheridan, CA
2.9
Looks good man I'm running the same springs in the front and personally I think they are way to stiff. Good luck on the build!
rangerdanger208
Idaho Falls, ID
ya they are a little stiff but feel a lot better than stock. I like the ranchos too I haven't ever upgraded offroad shocks
rangerdanger208
Idaho Falls, ID
made some hangers for the tire carrier.
rangerdanger208
Idaho Falls, ID
found some big washers for my hinge on the carrier.
rangerdanger208
Idaho Falls, ID
I have been thinking of moving this thread else where... I don't know if its because of the 4x4s aren't prerunners hype or if anyone is interested in a prerunner 4x4 build... but it seems like people aren't interested, aren't looking in here, or have any comments or opinions. any thoughts?? not trying to complain but I have seen this a lot on other peoples build threads as well
86MUDRCJ
8
Sheridan, CA
2.9
the prerunner section doesnt get action.id try the under construction section
jrs86
bullhead city, AZ
are you using a harbor freight welder?
