looking to get new rims and tires
Sub-Freq Ranger
15x10 or 15x8 ??????
2002 ranger xlt 4.0 with 4.10's 3in pa body lift 2in torsion crank with about 2in lift in the rear. i was looking at a set of33x10.50r15 toyo mt's on pro comp 252 15x10 -44 offset. my question is will the 10in rims work or should i go 8in?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
8" wide wheels would be much more suitable for those tires, especially if you plan to use them off road (10s put the sidewall almost vertical, letting it slip off the bead easier if you lower the pressure, not to mention will also leave the tire and wheel edge more vulnerable to damage from rocks, tree roots, etc.).
Sub-Freq Ranger
thank you for the info.
