looking for possible engine swap info
1986fordranger
central VT
2.3l/4.0l
hi i am going to be buying a 1986 ford f250 2wd with the 300 l6 to use for a parts truck for only $100 and i plan to take some parts off it that i need for my 1984 f150 4wd with a 351w v8 it seem to really sucks gas and i was thinking about swaping the l6 for my v8 to get better mpg and what i want to know is if its worth it or if i should just keep my v8 the v8 runs good just gets bad mpg ,thanks for any comments or ideas
mudseeker
Snyder County
5.8 HO
i would keep the 351 and switch over to an efi setup. the carb 300 is also a gas hog. if you are intent on the 300 i would switch over to an efi setup. you never stated what trans is in either truck. but you will need to change the bellhousing or the complete trans. hope this helps.
1986fordranger
central VT
2.3l/4.0l
thanks for the info mudseeker, both trucks have 4 speed manual transmissions so thats not a problem and both have carbs i dont like efi much , but if i where to swap it to efi how hard would it be to do it , also if the 300 l6 ran good and 4 speed manual transmission worked good what would you think i should expect to get for them if i sell them , i went and paid for the truck today so all i have to do is go get it when the snow melts , thanks
mudseeker
Snyder County
5.8 HO
the 300 inline six in good condition is worth roughly 150 to 200 bucks depending. the t18 4 speed isnt really worth anything to be honest. they were heavy, slow and are outdated. if you dont like efi, i would switch to a two bbl carb and manifold.
1986fordranger
central VT
2.3l/4.0l
thank for the info , i don't know if i will end up swaping engines its takes time and money to do and my 351 runs good over all , i just cant see that its worth it but i can't lose anything i can junk it and make back my $100
