Looking for a AC Diagram for 1986 Ranger
JKarels
MIlbank, SD
Ford Ranger XLT
Is there a Air conditioning electrical diagram that I could get from someone for 1986 Ranger (XLT, Auto, 2.9)
I would very much appreciate your help. Short story, AC Compressor won't kick in, not sure if it is a relay or what to do exactly at this point.
Thanks again.
Paulos
210
North Carolina
1987 STX
Here's some pics for the '87. I don't have pics for the '86, but it should be the same. Things I have found in the past that prevents the AC compressor from engaging; Low freon pressure, bad AC pressure (de-ice) switch or connector, bad AC clutch component(s). I've always understood the wide open throttle AC (WAC) relay to be normally closed, but it may be normally open (as the wiring diagram seems to indicate.
JKarels
MIlbank, SD
Ford Ranger XLT
Thank you, I appreciate it.
Danec71
Washington
I don’t know if you have fixed this yet. In my 1986 there is a 10 amp fuse behind the cigarette ash tray. Pulled it out and look. That was my issue
