Locking hubs for 2007 ranger
johnnybravo234
Is it possible to get aftermarket manual locking hubs for a 2007 ranger?
Toms01PSD
37
Sanford, NC
7.3
No. Why you ask? Because you have a live axle setup. Basically the front axles are spinning regardless of whether you are locked in 4x4 or not.
johnnybravo234
Exactly. I want to be able to disengage them to prevent wear to the front end and save some gas.
Toms01PSD
37
Sanford, NC
7.3
If you search through the forum you will find that they don't hinder fuel mileage anymore than a 98-00 4x4 truck. The only people who gain from manual hubs on 4th gen Rangers are 98-mid 00 folks with the PVH system.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
One way to get locking hubs on your '07 is to swap the '98-early '00 PVH hub parts onto it, then install a set of AVM manual hubs. There's been reports that the '98-'00 bearing assemblies are a little less robust than the '01up live-spindle bearing assemblies however (this may matter if you have larger tires on wider-offset rims).
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Frankly I think swapping 1998-00 Pulse Vacuum Hub knuckles onto a later truck to be able to unlock the hubs is like getting a sex change with implants so you can fondle some tits.
What you'd give up doesn't nearly make up for what you'd get.
And in the end "F**k me!" would aquire an entirely new meaning.
AD
Chris.S.
4
Kelowna, BC
AD
Good one! I lol'd at this analogy...
Beef52751
13
Eastern Iowa
2.9
AD
AllanD, you have some of the most screwed up analogies ever, but for some reason they make sense in my demented little head:icon_cheers:
