Limited slip spring?
gungfudan
19
Mississippi
Mazda
N/A
N/A
I was wondering if adding a trac loc spring /limited slip to my existing carrier will make it a limited skid rear end or are there other parts that are needed?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Clutches and plates
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
If it is and open diff you can install a lunch box locker.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I dont think placing a spring inside the differential is a good idea... it would most likely damage the gears.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
But they are special differential springs.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
3,614
An LS carrier has cutouts for the ears of the steels and the side gears have spline snouts for engaging the clutches. too. You can't just slap LS parts into an open carrier or it would be much more common.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
But you can a lunchnox.
And unlike a trac Lok.....they are not useless....and cost less.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
gungfudan
19
Mississippi
Mazda
N/A
N/A
I figured it wouldn’t be that easy but I had to ask. I really have never messed with a diff before.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,819
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Differentials are their own special kind of hell. Worth the effort to get what you want but the setup is a SOB. Look up Eric the car guy on youtube when he regeared his 8.8” for his Ford Fairmont (about 3 years ago). Frustrating as hell.
If you go to install a locker or limited slip other than what Bobby is recommending, that is what you are going to look forward to.
85_Ranger4x4
17,981
SW Iowa
If you want a limited slip on the cheap/easy you can look for another axle with the same gearing as what you have but with limited slip. Make sure it is in good shape and swap it in.
