did a small project last weekend.
I have been driving without a swaybar since I bought the Bronco and really not liking it on the twisting mountain roads where I live.
so I picked up a sway bar with all brackets at the local junkyard.
I needed to drop the mounting points with the 6" lift and did not like the 4" drop brackets that are available. So I cut some 3" tall metal square tube that I had sitting around and bolted it up using Grade 5 bolts.
Mixed results - Drives great on the road but with any flex the tie roads hit the sway bar.
so I had the sway bar end links from the explorer that I parted. they are 1.5 longer than the bronco 2 ones. Bolted these up - New problem the sway bar ends hit the springs.
Ok so now I took the sway bar mounts that mount to the bracket and moved them forward about3/4 inch. Did this by grinding about 1/4 off the front of the sway bar mounts. Then drilled new holes in the sway bar mount bracket to move the whole bar forward.
drove it again and have less sway driving on road. Also did a off road loop on my property and nothing hit.
Now I just need to get some tractor hitch pins to replace the bottom bolts for the sway bar links. This will make it a quick disconnect. also need to make a bracket on the frame to hold the sway bar when it is disconnected up and out of the way
Now I just need to find some cheap Jeep 4" lift coils and swap out the coils. maybe call the guy that I meet back in May about swapping springs.
Also found a piece of 1" think steel that is 6" long and 3" tall. if I get motivated I can move the center link points down by 2" as suggested else where.
