lift
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok so i wanna do the explorer leafs in back and coil spacers or whatever up front is there andything i have to do as in make anything longer or can i just instal the leafs and spacers and be done?
chrwilkins30
6
Mishawaka, Indiana
nothing needs to be made longer, just dont forget camber bushings and an alignment
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
what are camber brushings?
chrwilkins30
6
Mishawaka, Indiana
it adjusts the camber/caster when adding longer coils or a spacers, highly needed.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
about how much do they cost for a set?
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
oh and does anybody know how to take the gauge cluster out of a 84 cause i have taken all the screws out but it still is stuck in there and wont come out
chrwilkins30
6
Mishawaka, Indiana
They cost around 80 with tax and usually available at napa. You need them or your tire will get trashed quick.
On the cluster did you remove the speedo cable?
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok looks like i will need to save up money. and it wont even come out far enough to after removing all the screws it only moves out at most 1/8th inch
chrwilkins30
6
Mishawaka, Indiana
im not sure how to remove it, I just know you do. when i went to change a bulb, i never knew how to take the cable out so it just put it back together and didnt waste anytime trying to fix it.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
yea i have no lights for my gauges and i have a blue light i bought from walmart and i got pulled over lastnight for no lisence plate lights and when the officer walked up the first thing he said was the blue light is illegal so i need to fix the lights or he is gonna give me a ticket and he game me a fix it before i drive at night again ticket so when i fix it i have to go show the officer
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
can anyone help me on how to get my gauge cluster out of my 84 base model
4.0B2
151
Walls, MS
4.0 v6
w/ all the screws out, you should be able to pull it enough to get your hand to the back of it... IF not.... find where the speedo cable comes up from the floor/firewall to the dash and try to get some slack in it.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
yea i cant pull it out more than an 1/8th inch, so i will try and find the speedo cable from under the dash thanks
Yeah, you gotta get the speedo cable out or you can't pull the cluster out more than about 1/8". Reach up under the dash, find the cluster and the cable, then find the little tab on the cable collar and push it down while pulling back.
As to your lack of lights, did you check the fuse? Sometimes when one of those bulbs burns out the damaged filament will fall just so that it lays and shorts the whole circuit and blows the fuse.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
i got the gauge cluster out and checked every bulb and they all worked but yet it still didnt work in the speedo or gas gauge area but the seat belt,e brake, 4x4, and brights lights all worked, so idk whats up
No members online now.
