LED Dash Bulbs?
JDanger
I have a bulb or two out in the dash cluster and wanted to go with some LED's. Does the cluster use all the same bulb size? And what LED's fit the 03 cluster?
The dash illumination bulbs are 194s, the warning lights are something else.
Some people report issues with lights not working or being very dim after putting in LEDs in the dash. I have not had this issue, but sometimes my dash lights stay on.
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
Just be aware of what type of 194's you get, 20 SMD are tight.
JDanger
OK, thanks guys. Haywire, theres more than one type of 194 LED?
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
Yes. "194" refers to the general shape and size of the "bulb", mainly the wedge base. You can get 194 style LED replacements in various configurations, such as these pictured below. Not all will physically fit in your instrument cluster locations. Also, LED's use less current than incandescent bulbs, so they may cause some circuits to act strange. I used 5 SMD LED's (like the top picture) in the cluster in my '93 and took a couple of them back out because they stayed on all the time. I'll check my thread later to see which ones. Also, LED's have a polarity. they only allow current flow in one direction. So, They must be installed in the right direction.
JDanger
adsm, when the lights stay on, what did you do remedy the problem? Or did you?
chewy012
Colorado Springs, CO
4.0 OHV
I just did this a few months ago now, I wouldn't recommend it. Two work, two randomly flicker on and off. Plus they were like $4/ bulb. I'd stay with the regular ones.
Sent from my XT1254 using Tapatalk
85_Ranger4x4
17,854
SW Iowa
I went back and fourth, just got a 10 pack of 194 bulbs for $4. I have never had one go bad but while I have the cluster out I thought I would put new bulbs in it.
It only happened once. It may have been bleed-through at the switch, I don't know.
Dude, we 1st gen guys have it easy for dash lights. I can reach up there and switch out bulbs all the way up to the turn signal and high-beam indicators without taking anything apart.
ericbphoto
16,598
Wellford, SC
3.0L
6"
adsm08,
That is WAAAYYYY too easy. You should be punished in other ways to compensate. :icon_thumby:
85_Ranger4x4
17,854
SW Iowa
It is even easier when the cluster sitting on my kitchen counter after I painted the needles and updated the gauge faces. :icon_thumby:
I have had the truck 16 years and have never had to touch one... so I figured I am probably getting due.
JDanger
Now you guys have me on the fence on weather or not to go with LED's. Decisions.
Clatterman
So Cal
FORD
Excellent youtube on replacing Ranger dash bulbs:
Chrisfix https://youtu.be/qRMSvFO7org
I would only put LEDs in the bulbs that don't dim (such as the flasher arrows).
Conor Knoxx
Are the LED's dimable? I know with home lighting, LED's - some are dimable and some are not.
