Ld f250
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
what automatic transmission came in the 99 F250 that looks like the F150?
other question....... how do I decode the vin so I don't have to keep asking?
TheTopher
176
Delaware
2.3
https://www.fleet.ford.com/maintenance/vin_tools/default.asp for the vin
Here's a little info on your 250.
some facts about the 250LD/F150 7700
- 7 Lug Rims -
- They have a larger frame then the F150
- Bigger Brakes
- 3:73 rear end from factory
- 4R100 Tranny
- Extra leaf in back
- Larger Torsion bars -
- Heavier towing capacity
- Weigh more -
- Larger rotors, I believe 13.5"
- HD shocks
- power steering cooler
- 4700 lbs rear axle
- HD rad, thicker
- HD alternator
- HD battery
- LT tires standard, load range D
- the tranny is the same as a F250 SD and the F350 SD
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
Ozwynn
200
Berrien Springs, MI
RE Interceptor
thank you sir. I will bookmark that page on my phone aswell. I seen a couple real nice LD F250s ........ all things being equal they are about 2/3s the price if a Super Duty.
TheTopher
176
Delaware
2.3
No problem. I'm glad my insomnia was at least a little productive.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
apparently I can't view it on my phone........ is the F150 7700 the same rig as the F250 LD?
Seen one (F150 7700) in traffic today on my way back from drooling over 4 color back lit 55" LED 240hz full on 1080p 3d TVs at Best Buy and it appeared to be 7 lug.....
TheTopher
176
Delaware
2.3
Yea' the f150 7700 is the same as the LD250
When the super duty came out they just switched the name, I guess for less confusion.
85_Ranger4x4
17,953
SW Iowa
It was also when the '150 got a facelift, I always figured that was the reason.
Generally when I see one they have had the crap beat out of them.
They also have unique rims, I always wondered how Ford figured up that it was cheaper to design freakishly oddball rims for it than to throw another 4 studs/nuts on a truck and using off the shelf Super Duty rims. :icon_confused:
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
yeah, how hard is it to get rims for these trucks now?
(i just saw one for the first time, f-150 with 7 lug counted it about 10 times to make sure i wasn't seeing things)
85_Ranger4x4
17,953
SW Iowa
There are a couple aftermarket options out there, dunno if it is the same pattern but there are still making 7 lug trucks.
