bayouranger
- Jul 17, 2008
- 1
- Age
- 39
- Louisiana
- Ford
- Engine Size
- 3.0
I figure that this is the right place to post this, because it does cover a lot of issues other than simply tires, so who knows. Fact of the matter is that I'd like to put bigger tires on my 2WD Ranger Sport 3.0L, but my dealer told me that it could cause a lot of problems that wouldn't be covered under warranty (thus voiding the warranty.) I have 4.10 gears with stock 235/70/16 tires. I'd like to run 245/75/16 with a body lift or possibly a 2-3" suspension lift, but at the bare minimum I want the bigger and more aggressive tires.
I was wondering if the larger tire size would cause any transmission, drivetrain, brake problems or otherwise? I have talked to a lot of people who run MUCH larger tires who said it would be fine to run such a relatively small (comparatively speaking) tire such as a 245/75 over the stock 235/70, but it seems like EVERY Ford tech that I speak with tells me that I will run into a lot of problems uncovered by the warranty. I haven't even asked them if putting a lift on my truck would be adding fuel to the fire. I don't even off-road aggressively in this truck (I have a ragged-out Jeep for that.) This is my daily driver that I'd like to make a bit more off-road worthy should the need ever arise since I drive on a LOT of farm roads and other un-paved roads when it gets wet and sloppy -- basically I just want to prevent getting stuck on a sloppy and unpaved road as well as increase the stance/appearance of my truck.
Usually, I couldn't care less about lifting and/or putting larger tires on my vehicle, but since this truck is relatively new and I have a warranty, I don't want to be pissing in the wind so to speak. It is the first new vehicle I have ever bought.
Thanks a ton.
Thanks a ton.
