Larger capacity oil filter.. is there one ?
AngelEyes
NC
FORD
For my 01 4.0L . Using a NAPA 1372 short thing it is , can't seam to fine a bigger canister oil filter for it that has METRIC threads.
Is that a SOHC or a OHV? If it's an OHV then the FL-1A is pretty big, that's the OEM filter.
If it's a SOHC, I dunno what to tell you. The SOHC just calls for short filters.
AngelEyes
NC
FORD
Yep SOHC , About what I have found out only the shorties , Thanks for the reply .
Just use the Motorcraft FL-820S. If it's big enough for a 6.8L it should be just fine for a 4.0.
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
You can swap the filter adapter from an older 4.0 on and run the fl1a without much trouble
AngelEyes
NC
FORD
Thank you for that piece of knowledge :headbang:
You know, I experimented with that possibility when I was building my OHV, because I wanted the newer adapter to run the more widely available FL820S.
It turned into a dead-end because I got impatient and could never confirm that the block side of stuff was correct.
holyford86
610
Plattsburgh, NY
many
33x12.50R15
The block sealing surface has never changed, back when I rocked a 2.9 I used a filter adapter off a 98 4.0 because I couldnt get the copper washers to seal well, I know the block side stayed the same till at least 04. The center bolt changed throughout the years but the thread and sealing surface didnt.
I know the sealing surface is the same, it was the threads I was unsure of.
I had briefly looked into putting the piece the filter threads on to into the older adapter, but obviously the threads were different.
holyford86
610
Plattsburgh, NY
many
33x12.50R15
Yeah I wouldnt think it would be that easy
No members online now.
