lack of oil causing engine clatter?????
fordman4x492
berwick louisiana
5.oh 3oh2 v8
ok guys i got a 86 ranger with a 302. its got a high volume oil pump, fram oil filter on a filter relocator kit. when its running it has oil flow but it clatters a little. im thinking that shitty fram filter is restricting the oil flow. what do you guys think?
morse johnson
Yeah i agree fram oil filters are shitty lol...you didnt say if your motor has been rebuild or not oil pump doesnt make oil psi but a good set of crankbearing will jack your oil psi up..also you could have some clogged push rods
I think that using a fram filter is just asking to need a new engine.
baddad457
18
Opelousas La.
Well it would be simple enough to swap the oil filter for Ford FL-1A. If it's still clattering, then you'll know the filter wasn't the problem (and I doubt it is) If it's still noisy, add an extra quart to the crankcase and see if that stops it. If neither of these two help, you may have more serious issues.
littlezell
Young Harris Ga
I use fram or motorcraft on my Ford Engines and I havent had any trouble out of either or... I think you have some internal damage.... do you know what your oil psi is?? try adding some lucas oil treatment...
fordman4x492
berwick louisiana
5.oh 3oh2 v8
The motor is rebuilt and the oil preasure is about 50 psi
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Is oil getting to both heads or just one? Have seen this before and the cause was the cam bearing had not been put in correctly causing a lack of oil on one side.
morse johnson
also this could be a bad wrist pin
bearsrngr
5
Wayne Nebraska
You may also be missing a lifter oil gally plug at the front of the block.
fordman4x492
berwick louisiana
5.oh 3oh2 v8
Ima try changing the filter and see if it helps if not ima tear it down and check it out
motorbill87
Arlington, Texas
5.8L/4.6L
If you used silicone excessivly on gasket surfaces you may have some clogging your pick up. Make sure your rocker arms are tight too.
