Kill Switch?
djk
Wisconsin
2.9 ltr.
Something very confusing has been hapenning to my ranger. whenever i go over a big bump or railroad tracks at a normal speed my ranger shuts off for a split second, not even a second, like a 10th of a second. but you can notice because the engine hicups and the Red brake light flashes on for a split second. Any of you guys have an idea of what could be causing this.
4.0B2
151
Walls, MS
4.0 v6
i'm gonna say you have a bad ground or wire somewhere... that's my guess.
straycat
77
02 06 and 2012
Jeeps
There could be something else...the inertia switch. This is a switch usually located under the dash. This is a switch that if an impact happens the switch will activate and shut off the fuel supply so no fire will happen. This switch could be going out.
Anybody else???
'99 EB Explorer
55
Sudbury, Ontario, Canada
Check/clean your battery terminals. I'm leaning more towards electrical issue.
4.0B2
151
Walls, MS
4.0 v6
the inertia switch- if it goes out it should GO OUT.. not just flicker the stuff. the inertia would only cut the fuel off- not back on till reset. that's why i said electrical. probably something stupid simple.
gribly
28
Maine
Honda
K20A3
Jiggle the keys with the engine running?
djk
Wisconsin
2.9 ltr.
Thanks for the suggestions! If it were the ground to the battery wouldn't there be no lights on when it flicks off? And if it were the inertia switch where around the dash would it be?
17,920
SW Iowa
I had one just barely unplug once...
But I agree, if it is messing with stuff on the dash, the inertia switch isn't it.
Beef52751
13
Eastern Iowa
2.9
i think its a loose ground somewhere too.
straycat
77
02 06 and 2012
Jeeps
Not really. The inertia switch could have a interminting issues and this could cause the problem as well. I know of this happening to about 3 Chevy's and two Rangers and a couple of F150 at a few dealerships. The switch was checked and replaced and the issue was solved.
djk
Wisconsin
2.9 ltr.
ok well in the meen time i'll pop the hood and look for loose grounds and check online where the ininertia switch would be because i don't think it'd say it in my manual
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
My F.I.L. had a similar prob with is truck.....nearly drove him crazy (&me craizierieir).......finally I cranked the truck.....took each wiring bundle inmy hands & flexed them all kinds of ways......took an hour....
finally got the engine to skip a beat in one bundle......wiggled each wire at the connector in the suspected bundle....found a wire broken INSIDE it's covering about 1/2" before it entered one of the connectors!
Truck would kill completely when I pulled on the bad wire.....repaired it/no more problems....
4.0B2
151
Walls, MS
4.0 v6
Inerhtia switch is usually under the carpet towards the center on the passenger side of the truck.
djk
Wisconsin
2.9 ltr.
ok, i'll check it out when i get the chance, i'm hoping it's not some random wire dug deep into my truck that has a bad connection, could take forever to find
robertc1024
133
San Marcos, TX
nada
2.9
I'd definately try wiggling the ignition switch. I had a similar problem on my '88 and that was my problem. If you take the covers off of the steering column and look under the switch, there's a "plate" that's got electrical contacts on it and it's held on with some bent-over metal tabs. The tabs had gotten loose over time. I put a punch and hammer to them to tighten them up and, voila! no more problems.
