Just picked up another 302
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Found this on the local ads for 100.00. Looked clean. Spins free. Came with the intake. Took a gamble. Looks to be a 77-81 block. So gonna need to scrap those heads ASAP
BSwift
Oklahoma
Nice find! I'm on the hunt for a 302/C6 combo as well. May have a line on some 70's Ford 4x4 drive trains as well. It's only money, right?
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
Those must be very early 77 heads because they have rail rockers, if you decide to use them I'd recommend converting to rockers with guide plates instead. Rail rockers put tremendous side loads on the valve stems and cause guide wear. It doesn't look to have a cylinder ridge, hopefully you can just hone it and rering it. Ford always said to never bore a 302 beyond .030" but for years in the late 70's/ early 80's we got Ford remans with .040" over pistons so you should be able to get away with a slight overbore if needed.
RangerFabWorks
715
302
I had a local machine shop check it out. They said it’s fine to run as is. Just clean it up.
I also picked up a set of completely rebuilt e7 heads for next to nothing. So gonna do some port work to them. And convert them to stud mount rockers.
19Walt93
4,482
Canaan,NH
351
3"
235/55R16
The E7TE heads are pretty good, not GT40's but pretty good. Compared to the rail rocker heads they're wonderful.
