Just a "TOY"
Phantom
Salida CA
So it's been about 2 months of admiring everyone else's rig in here, I thought I would post a little bit about mine..
Purchased this b2 about 2 months ago with no transmission and taking the guys word for it that it ran for $800... This is how it looked after a quick wash..
After stacking the torque converter on the first tranny and acquiring a tranny that had a 2 pin instead of a 3 pin connector valve body I have finally installed the correct tranny and got it to move, only to find out the left tire rubs when turning sharp to the left... After looking at it and not catching it upon purchase I found the left side radius arm and bracket has been pushed back.. Most likely from being jumped.. The James Duff long arm kit along with the 2" body lift shows up tomorrow... Just wanted to share a little history of the projects, and now for the pics of the progress done today... Decided I needed a safari rack, on board air plumbed to a 5 gallon tank, and put the Goodyear 33" MTR's on it...
Safari rack in the build
On board air
The 33's
The way it's sit's today which will be changed this weekend, due too the parts showing up..
ImageUploadedByTapatalk1374703944.288735.jpgImageUploadedByTapatalk1374703961.689389.jpg
Thanks for reading and inspiring me on what I want to do next... There will be many of more options I will be adding to this "TOY"
Let me know what you all think..
This is not and will not be a daily driver it will be built for the trail...
4.0B2
151
Walls, MS
4.0 v6
subscribed.
integman
well, looks like time for dana 44 lol nice rig
Phantom
Salida CA
I'm a bit indecisive on the axel situation, have a d30 sitting, but leaning towards buying an explore complete for the 4.0, D35, 8.8 rear with discs... The d44's would be an awesome addition though...
Surrey
10
Vancouver, Canada
d30 is nice, but if your gonna go through the work of a SAS, might as well go big or go home right?
Also, I think the d35 is technically stronger than the d30.
Phantom
Salida CA
I like the way you think... However the the Duff long arm kit just showed up, so I'm thinking it will the d35 ttb next.. My brother has been trying to talk me into going d60's, but I can't seem to talk my wife into letting me spend 6000 in axels just yet....
wildbill23c
Ham Radio Operator
578
Southwestern Idaho
215/70-R14
Damn nice B2. $800 and you had to put in a tranny, not too bad. Given it being an 88 model it has Overdrive I would assume? Seems once they put those overdrive automatics in the rangers and B2's is when they started having transmission problems. Can't remember which transmission was in my 84 Ford Ranger but it wasn't overdrive just the 3 speed automatic, it towed a 16' travel trailer all over the country and never had a problem.
That onboard air is a great feature to have, and the new tires made a huge difference. I like it.
Phantom
Salida CA
Yeah it's the a4ld auto with overdrive... Not too wild about the tranny but we will see what happens. Just finished the 2" body lift, I'll post pics tomorrow, now I start in on the Duff long arm kit... Can't wait to hit the trail....
bIIjr
southern pa
nice bII looks like mine before I started hacking at it the oba is a awesome feature I love it
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Put an external auxiliary cooler on that A4LD and it'll likely be fine. Insufficient factory cooling is what leads to a lot of failures and them having a bad rap.
Yes, stronger ring & pinion and housing. The D35 also has larger axle u-joints than pre-'95 D30s (same as D44, or post-'95 D30s).
Phantom
Salida CA
So here it is after the 2" body lift and the James Duff long arm kit... I will take better and more pics in a few days, as for now I am beat!!!
Phantom
Salida CA
So picked up this little trailer for the b2, only 600$ and should be perfect for short get aways... Now for the lift on the trailer, thinking 31's will look good under it.... Plus I added the external tranny cooler to the b2.. The first thing I did along with the explorer rad....
wildbill23c
Ham Radio Operator
578
Southwestern Idaho
215/70-R14
My grandfather's 93 Ford Ranger A4LD had the external tranny cooler added when the tow package was put on and the transmission still failed in it twice, so the cooling isn't the whole problem, the transmission is just garbage.
Stay out of overdrive towing that trailer and you might be ok. After that 93 Ranger I refuse to even look at a ranger past the early 80's with an automatic transmission, seems after they added the electronics and the overdrive the transmissions went to crap. My 84 B2 had the TK-5 manual and it seems to pull pretty well even with oversize tires, can't wait to get the right size tires put back on it, that may give it even more of a power feel.
Your B2 looks really nice, and I'm sure you will get many years of use out of it. I really like my B2, even with all of its issues I toss around the idea of selling it when something goes wrong, but for some reason I just fix things as they happen and just keep driving it. I saved it from the wrecking yard, and by looking at it that's probably where it should have gone, but I drove it around when I first looked at it for about 45 minutes and it ran and drove great, so figured a little body damage here and there isn't gonna hurt it, eventually I plan on slowly fixing the damage and get it repainted but until then its my beater daily driver.
Phantom
Salida CA
I know all too well about ford transmission I'm on my fourth one in my 2002 7.3 super duty.
I have a 40' fifth wheel toy hauler I pull with it... Finally built a mostly billet internal transmission... Mostly due too my fault of not down shifting to lock the torque converter up.. This won't be towing this trailer often.. Thanks for all your guys input....
