you and me both brother.
well, gotta little update. I worked on getting some things done to the truck. One of the things i needed to fix ASAP was the little bit of DW that it still had. Fixed that with a complete re-balance of the wheels. This time with weights instead of BB's.
also noticed a while back that my track bar mount had cracked the frame, so a buddy let me borrow his welder and i went to work. Made a couple of pieces that connect to the bracket and to the engine crossmember. MUCH stiffer now. Only problem is the pump isn't liking the extra work, so Hydro assist setup is next on the chopping block. I'll have it in before Rubicon.
Also replaced the A/C stuff. My hose that ran to the compressor had a hole in it, and the accumulator was shot, so I replaced both of those. Going to get a remanned compressor off ebay. They have them for like 70 bucks.
Picked up the fuel lines and the barbed fittings to extend the gas tank lines as well. Just waiting on the tank to get here first.
Took a couple pics of the truck and the "gussets"
