Jarhead choptop
Jarhead
U.S. Military - Active
NC
1997
There is nothing too it. However, you need to have a plan on what to do with the roof line and cut lines. I am thinking about taking so 1/2 conduit pipe and finishing the cut line with it. Anyway, good luck with whatever you decide.
cobra18
An easy trick to the roof cut lines is to cut the interior side a bit shorter than the exterior metal then cut slits in strategic places to make tabs in the metal and fold them in over the interior that you cut shoter to make a nice clean seam and look somewhat like it was meant to be. Then you can mig weld the seam where tis folded against itself to keep moisture out and prevent rust. ( A common Bronco II issue as it is. ) Quick, easy, and cheap.
Tony Raine
17
Jonesboro, AR
302
your build looks good, i just have one concern. how thick of metal is that "roll bar"?
Boggin
48
i wanna do this and i got a set of normal truck roll bars i will be putting in, i was wondering what you do when it rains? thanks
Jarhead
NC
1997
Sorry but I have been moving into a new place so the bronc is a little bit "on hold".
Tony - It is a pair Jeep roll bar. They are just tacked into place and bolted in. This is a temporary mockup until I figure how exaclty I want it. I have found a place that will make a hoop out of .175 tube.
Boggin - I have it covered with a tarp right now :yahoo: I am going for the rhyno lining once I have everything done. I still need to relocate the brake control to the driverside firewall. It is not a daily driver - yet.
Semper Fi
Jarhead
NC
1997
Back to working on the Bronc. Anyone know if it is cheaper to rebuild an engine (2.9L) and tranny (18 bolt 4ALD) or to buy a reman?
IlovemybroncII
greenville sc
1998
198
Chev
For
350/2.9/2.9
its about a 1000 for reman tranny
Jarhead
NC
1997
Been awhile since I have had a chance to update the build but had to take a little trip, er well a long trip. While I was gone, rebuilt tranny, new starter, a little body work and a quite beefy roll bar from a buddy. It is taller than the bronc but will become the back of a cargo cage on top.
Niles1321
hey man, do you still have the liftgate? I just ripped a huge hole in mine driving it into the garage. I forgot I mounted the high lift jack on the back sticking up... lol
Jarhead
NC
1997
Sorry dude, left it in VA. If your near Coastal NC, I can put you on to a guy parting out his B2. I saw one on Craigs list for 75.00 also
Loveland CO
2.3L 4Cyl, 2.9 EFI V6
What part of coastal carolina? Im in carolina beach, wilmington area all the time!
