P93suafilo
- Mar 23, 2015
- 14
- Lehi UT
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
So I am currently collecting parts to do a 44/9 SAS on my 94 sport. The goal is to build a low COG stable streetable crawler.
The plan is to use the James Duff(JD) Radius arms on the front w/ the full width 44 (79 F150). The axle I have is the cast style knuckle w/ cast wedges and I am unable to move the wedges inside and reuse the standard coil buckets. I have done alot of research over that past couple years but am still unsure about a couple things most of this stems from not being able to view photobucket images anymore. My plan is to use this set up because of my limited fabrication skills.
Does anyone have any gripes about the JD radius arms? So far everyone I have talked to love them.
Does anyone have experience w/ this setup, and can share some advice of what they did for upper/lower coil buckets(photos are very welcomed)? JD has these Coil Buckets (Full Width Axle Offset Coil Buckets 1966-77 Classic Early Ford Bronco) has anyone used them?
