It sounds like its the wheel bearing,, BUT--
AaronC47
Pacific NW
94
Mazda
I have not really seen much about my issue, and I am wondering if I am on the right track. You know when your wheel bearings are goin bad and gets worse as you round corners, I took mine all apart cleaned all up, put it back together and Im ready for that noise to go away. And there it is again. It seems the U-joint in the axle is wearing and the end of the axle appears to be scarring and or just rubbing real hard on the inside of the stock hub cover. I have another axle I am gonna change today, BUT I cant really figure if its the U-joint or one or both ball joints. It drives fine for having 206,000 miles (93 Mazda Navajo). Its a mild constant grind as I drive and get alot more severe in corners. Any Ideas guys ? I would rather just fix it once (again),, ugh
AaronC47
Pacific NW
94
Mazda
OK Never mind anyway,, I was just kinda stuck on stupid there for a bit, I never thought about the spindle bearing in the hub. I am gonna go change it out and see what happens. I have extra parts vehicle so this will be quick easy and painless, I hope.
