ISO Retainer Springs & Roll Pins
GriffinM6
ASE Certified Tech
4
Chehalis, WA
Ford Ranger STX
2.9
2 inches
235/75r15
As the title says I’m in search of the rocker rail retaining clips and pins for my 93. I didn’t realize how hard it would be to find these parts so while I was dismantling my rails to replace the rockers I messed up the originals. Does anyone have a link as to where I can find/order them or any knowledge on the subject? I’ve searched high and low on the internet to no avail even went to fords website without success. Only other option I could think of is to go to a u pull it yard to grab used ones but would prefer new if possible.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,767
Wellford, SC
6"
Measure the size and order from an industrial supply place like McMaster-Carr.
GriffinM6
ASE Certified Tech
4
Chehalis, WA
Ford Ranger STX
2.9
2 inches
235/75r15
Thank you for the response I really appreciate it! for the roll pins that would work for sure and will probably be the route I take for the cheapest solution. My main issues is honestly the spring/retainer clip that is shaped in a rather unique way so that it keeps even pressure on the outside edge of the rocker arm while being held in place from this small pin.
downer
4
97 4.0 OHV 4x4
I have my old motor I can pull the pins and clips off if you'd like. It's going to junkyard otherwise. Assuming the cam rod end clips and pins is what you need?
ericbphoto
16,767
Wellford, SC
6"
Wow. Those rings are kinda special looking.
