Is this the superlift kit?
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Says it comes with the knuckles according to superlifts install manual every part ends in 9630 minus the shocks and knuckles. But summit racing says it comes with the knuckles.
All I'd have to do is buy rear blocks/shackles. And shocks, anybody got a p/n for front shocks? I figured to save a little money I could always weld a bracket onto the lca to have a normal shock to bolt to
cp2295
7
Washougal, wa
Okay what about using the superlift components but putting coil overs in to rid of the t bars
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I have seen a kit that someone offered to allow coil overs to be installed with the super lift kit....was a set of weld on brackets for the lower control arms. Can't remember where I saw it now...
cp2295
7
Washougal, wa
Okay but I can just make some brackets wouldn't be too hard I don't think? Just use some 3/16 or 1/4 plate and gusset the upper shock mount
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Pretty much what the kit was
cp2295
7
Washougal, wa
Where did you find that? I would rather keep my truck ifs (but get rid of the tbars) and sas a beat up bronco 2
