Is this bad?
Rose2300
7
ID
Toyota
3.4
So I changed my oil today and noticed I was 1/2 quart low. Is my truck burning oil or should i not worry about it?
whale
Bitterville
4.0L Gas Hog
Do you see blue smoke out the exhaust? Do you see fresh leaks where you park?
When was the last time you topped it off / changed it? I mean, if it was 6mo ago and you lost a 1/2 quart, I wouldn't worry about that.
Will
Rose2300
7
ID
Toyota
3.4
no blue smoke, and the oil change before this one was about 3 1/2 to 4 months ago. no leaks either and the engine is dry as a bone on the outside.
whale
Bitterville
4.0L Gas Hog
I personally wouldn't worry about it.
Will
cody93
42
Duluth GA
FORD
RUN ER TILL SHE PUKES! just check on the oil cap/coolent ocasionally to make sure your heads not cracked, if it looks like a chocolate milkshake, then your screwed
Sunk
125
Everett, WA
3.5 Eco
More importantly, how many miles has it been since you changed the oil? Unless it was only a few hundred miles, I wouldn't worry about it.
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
Nothing is wrong. Almost every engine burns a little bit of oil.
06RangerXLT
54
Georgetown Ontario
your gonne be fine. just to be sure, ya did a filter right?
i bet it just didnt have to correct amount in it before.
Rose2300
7
ID
Toyota
3.4
yeah did a filter. the old oil looked used of course but not milky so no cracked head, and the last oil change was around 3600 miles ago
cody93
42
Duluth GA
FORD
i wouldn't loose a second of sleep over it, unless you see blue smoke...
Rose2300
7
ID
Toyota
3.4
3,614
Only 1/2 a quart low in 3600 miles?
I used to have a car that would lose 4 quarts in 360 miles. That was a problem since it was a 4 qt engine.
88SXT
9
Beaufort SC
shit i have to check my gas every time i stop to fill the oil, but my 2.9 has god knows how many miles on it, misfires and runs rich as hell. no worries tho, i've got a 302 waiting to swap in as soon as i get back from this damn deployment
straycat
77
02 06 and 2012
Jeeps
Just keep an eye on it. It should be fine. You should check all fluids and tires at least once a week. Take care of your ride, Bro!!!!
snake
4
canyon lake tx
3.5
Many moons ago a friend of mine bought a ford van with a 302 in it- it used quite a bit of oil right out of the box. Ford told him if it used a quart every 800 miles or more it was normal...
I had a 91 Mazda (jap engine) that used a quart every 2500 miles, I was doing 3000 mile changes. I switched to synthetic, same brand, same weight, and it went 6500 before needing a quart. I went to 8000 mile changes because the oil was still clean looking until then. That really doesn't make sense why it did that but it did. 1/2 quart in 3600 is fine. If it gets dirty really quickly it could be a sign of blowby/ring wear. Still not a big deal. Pour oil in it and ride.
