Jay11
- Jan 17, 2019
- Reaction score
- 7
- Location
- Texas
- '99 4.0+'98 2.5
- Make / Model
- Ford Rangers
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 & 2.5
- Automatic
- 2WD / 4WD
- 4WD
In a car that has sat unused for the better part of a year I found the battery was dry. The bat. was getting discharged/or unable to hold a charge while it's barely 3 or so years. Reason, popped the caps and found it had zilch bat. acid. Not even a drip, in any of the cells. Refilled with DI water and all cells test about 2ish volts. I don't want to give up on this bat. yet, it's an AGM type.
Question is I know we can refill with DI water when acid is running low but can it be filled with no acid but DI water only?
How much acid is in a 12v Group Size H8, 900 CCA battery or any regular size 12v car battery?
