Interior Dome Light won't turn off???
atomicjoe23
My interior dome light just decided that it wouldn't turn off in my '99 Ranger. . .and the door ajar alert on the dash stays lit. I've repeatedly tried shutting the doors and making sure nothing is keeping them from shutting completely (like a seatbelt not retracting), but the light and alert still stay illuminated.
I looked for the pressure switch that is on most vehicles, but I can't seem to locate it.
Could someone clue me in where the pressure switch is so that I can replace it and hopefully get the light to go off. . .sucks to pull the bulbs and not have interior lights in the early morning/evenings.
Thanks!
Chris M
Central New Jersey
This happened in my 96. most of the time all you need to do is spray silicone or WD-40 on the actual door part of the latch, the part that grabs the U shaped part on the door frame. For some reason the sensor gets stuck open and this seems to solve it. This worked for me hopefully you too.
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
Thanks!
That particular switch is inside the door right under the door latch mechanism. A pain to get to. A 1/4 turn will get it out from its' mount, unplug it and plug a new one in (about $10 last I did one).
The lubricant trick may work, but is not guaranteed to last.
atomicjoe23
Thanks, I'll give that a try. . .
No wonder I couldn't find the switch!
very common problem. Ours started doing it a few years after we bought it, still haven't replaced the switch.
The Fix:
http://www.therangerstation.com/forums/showthread.php?t=270
Thanks for the link!
