I cant identify some things
bensemailis
New River, Arizona
2.9
Ok, so I finally took the plunge and bought a Bronco II. found an '86 Eddie Bauer.
I have problems with it that I am trying to fix, but am just unable to.
1. when sitting at idle, if I engage the AC compressor it sputters down and dies. if I am on the highway it is fine. I tightened the throttle screw a bit, because it was almost falling out, I will have to test the AC tomorrow.
2. Power loss. After running the truck for about 15 or 20 minutes, it has a loss of power when I push the throttle in, if I keep the throttle easy, I can slowly accelerate. But if I push in more, it stops accelerating all together. I havnt tried flooring it at that point, because I am afraid to break something. The problem goes away after the truck cools off.
I have seen a few threads about issue 2 but havnt seen any real solid suggestions. I am considering ordering a new TPS. If I could figure out how to get to the TFI I would replace that too.
I was also unable to identify some things under the hood. There are 2 connectors on the passenger side, coming out of the wiring bundle. They go to nothing, and I am unsure if this is supposed to be this way. I am including pictures to help. one red larger connector, and one small white connector.
The second is a 2 section box, that has 2 caps in it. It appears like it should have fluid in it. It looks like the piping feeds into the intake, and I am unsure exactly what it is. It is located up in the front on the drivers side. lower in the engine compartment. I have included a picture of this as well.
I am hesitant to take it back to mechanics, as they seem to not be able to recreate the issue I am having, and keep telling me the truck is in overall great shape.
BTW its a manual, and does have 90+k on it. It was a motorhome toad most of its life, so I am unsure how many miles are actual driving miles on it at this point.
Thanks for helping a newbie in advance!
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
charcoal canister... no its supposed to be dry inside. don't open the caps.
and the plugs are the diagnostic connectors. they plug into a scan tool.
There is a tool for the TFI, called a "Ford Ignition Module Tool". Can be had at Advance Auto for the princley sum of about $5. Helps a LOT.
As for your bog down issue, TFI could certainly cause that. Also replace fuel filters and check fuel pressure when hot. That really sounds like a fuel pump about to die.
bensemailis
New River, Arizona
2.9
D'oh... I didnt even think of the fuel pump. The low pressure tank pump was replaced, but not the main pump. That would make sense. I am no guru with cars, I know just enough to make by. How would one go about testing the fuel pressure?
The truck only has the power problem when in gear an trying to move, if that makes any difference.
and that tool looks AMAZING. I might just buy it to have on hand, since Ive been seeing a lot of talk about TFI failures.
bensemailis
New River, Arizona
2.9
my dad popped them open, should I be worried?
trail B2
8
North Eastern Ca.
My 86 didn't come with air but didn't that era of car come with a solenoid on the throttle that electrically raises the idle when you turn on the air?
That would be consistent with what I was thinking too. The lift pump wouldn't be as likely to cause your problem. The fact that the issue is only present under load only helps the case for a failing pump.
There is a test port that looks like a valve stem on the fuel rail. You'll need a pressure gauge.
TFI failures are more common of these trucks than on the fullsize ones. Its due to the position of the module. I have two of those tools, that's how handy they are. That's also how often I misplace things.
Nope, not unless he poured liquid in there. Not all of them came with two caps, only the Cali emissions ones. My 87 is Federal emissions level, and it only came with one cap.
bensemailis
New River, Arizona
2.9
I just ordered the Haynes guide for it. I was thinking Chiltons, but I had heard the bronco II chiltons was more disorganized then others. Looks like I get to learn how to install a fuel pump :icon_bounceblue:
And I wonder how I could properly test for this problem, since its hard to be under the hood while driving :icon_confused:
bensemailis
New River, Arizona
2.9
Oh, I forgot to mention this truck has been sitting for god only knows how long, at least 2 months I know of. Without usual driving. had very little fuel, and I filled up the tank, added lucas, and a new fuel filter.
I've used all 3 major manuals for these trucks. Chilton is disorganized, Haynes is lacking in useful info, and Ford's manual is hard to navigate if you aren't familiar with the system.
Haynes is good if you have it. Frankly, for an amateur I'd use a combination of Haynes, Chilton, and TRS. If you can get your hands on a Ford manual, do it. Once you learn how to get around them, they are great to have.
The rail pump is pretty easy though. As for the test, get a long tube for your pressure gauge and run it inside the cab and go driving. That's how we do it at the shop.
will1861
Gainesville Ga.
2.3
Plus 1 on the dealer service books. You can find them on Ebay for around 30 bucks for the set. Just make sure to get both books in the set. Haynes are good for general items. :icon_thumby:
bensemailis
New River, Arizona
2.9
That makes perfect sense. Guess I will be hitting up Autozone at some point.
I am hoping the haynes will have some sort of layout for connectors, I found 2 under the dash in the center, no idea what they do ha ha. and finding that A/C solenoid would be helpful too.
bensemailis
New River, Arizona
2.9
thx for the advice, might just have to do that.
I also have 2 connectors under the center of the dash, right by the shifter, no clue what they are for. Never bothered to look into it, probably for a fancy option I don't have.
What A/C solenoid?
kimcrwbr1
46
maplevalley WA
2.8l
Do you know how old the plug wires and the PCV are replace them so you know.. If you havent give it a good tune up preventative maint is allways the first thing you do. Oil change, filters and inspect all the connectors and wire good. Make sure the charging system is up to snuff. Check all the vacuum lines for hardness and cracks. Use the tech library and ask Qs. Dont change any components until you give it a good once over and # 1 is to do a compression/leakdown while hot to see if it is mechanical. No sense on spending money for the igniton if you problem is elsewhere.
