I bought a High Rider...
85_Ranger4x4
18,003
SW Iowa
Looks good!
I learned when I did my floor pan that whatever steel Ford used to build cabs... ain't fun to weld patches in.
My chinesium replacement pan was thicker and easier to work with lol.
Junk Collector
Truck of Month
4,870
Rapid City SD
What are you using to weld on your body panels, MIG or TIG?
MIG, with gas, .025 wire. I have a TIG welder but I'm not proficient enough with it to try something like this - maybe someday.
Looks good!
Ha, yeah, agreed. The irony here is that I'm using a piece of a 70's Lincoln hood that I found in the woods for patch material! That hood provided me with a lot of nice flat material over the years.
BlackBII
Ranger Custom
Truck of Month
984
UT
Looks good!
I'll second the difficulty in welding these cabs; the metal is crazy thin. I pulled a few dents in my cab right behind the door and the studs would just tear a hole in the steel when using the slide hammer, it was super frustrating. And then welding up the hole with my mig required adding some small pieces of steel behind the panel so that the hole would stop getting bigger. Like welding a piece of paper.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,785
Wellford, SC
3.0L
6"
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The "High rider" package is really nothing special, it isn't really a "lift kit"but it is a bit more than a "leveling kit" it was actually a zero cost option add on to an STX package truck
Junk Collector
Truck of Month
4,870
Rapid City SD
Had a 50+ degree day yesterday so I took advantage and did a bunch of sanding outside. The roof is mostly done and I started on the B pillars as well. I found some surprises - namely, 10 layers of paint and more holes in the roof. I am pretty sure this truck had a visor on it at one point, which caused the big rust hole... there are 5 screw holes on the other side in the same spot, although not rusted through that I can see, thank god. I think it also had lights or something attached to the roof as well - two more pairs of holes on both sides. This was all covered up by a very thick layer of bondo. There was also a lot of surface rust under the first layer of primer - I think somebody used the old "paint sticks better to rust" theory.
Fortunately the back wall of the cab and and the door jambs don't have that much paint so it will be easier going. I may just scuff these and prime. I probably wouldn't have gone to the extreme of taking the roof and pillars down to bare metal but I was having chemical reaction issues with the passenger door and did that with it, and I'm kinda glad I did it on the roof too so that I found the holes and have a chance to fix them now.
As you can see - bare metal, primer, base, base, clear, primer, base, clear, primer, base, clear :bad: Too much!
And surface rust underneath
Screw holes in the roof
I tried to just fill in one hole and of course it got bigger. I can't get in there with my copper backer strip so I screwed some bolts into the holes, cut them off, used a body hammer to dimple them down a bit and welded them in place, then ground the weld somewhat smooth and covered with filler.
No more holes on this side
Still have a long ways to go on the cab. Hopefully I will have a few more nice days in the near future so I can finish sanding outside. It's really nice to just let the wind take the dust away instead of sweeping.
Remember, safety first, wear your seat belts
Junk Collector
Truck of Month
4,870
Rapid City SD
Had another nice day last Sunday and was able to pull it outside for more sanding. I just can't stop finding more dents... and rust... sigh.
This one I knew about. It happened when the truck got wrecked previously, when the frame bent, it forced the box into the cab. My buddy pulled it partways out with big screws and then put a ton of bondo over it. I almost left it alone but found layers of paint embedded in the bondo...it was just not very well done. I got it somewhat straight with a stud welder. Instead of 3/8" of mud, it's got like 1/8" at most. I had to weld a bunch of screw holes shut here too.
This one, I was not aware of until I pulled the window out and saw a chunk of pink stuff sticking out under the rubber seal. It was pretty deep and had at least 1/2" of mud in it and rust underneath (shocker I know.) I got it pulled out and just a light coat of filler was necessary.
Currently working on smoothing out those two spots, another hole rusted through the roof on the driver's side and the cowl... someone removed one of the bars in the cowl vent so I'm fixing that. I really thought about swapping on a 2nd gen cowl to prevent leaves from falling through but that would be a pretty extensive project, and not one that I want to attempt right now.
BlackBII
Ranger Custom
Truck of Month
984
UT
The thinner the bondo the better! It's looking good man.
It's amazing how many dents you find once you start looking to fix them. They are never ending these trucks from 1. Being 30 years old, and 2. Being used as work/farm trucks. I got a ton of practice fixing them when I did mine, which is fine; more skills is always better!
Junk Collector
Truck of Month
4,870
Rapid City SD
Thanks! Yeah, it's a battle. I'm getting better with the stud welder... I tried it on a couple other projects and ripped the studs out, leaving holes in the material. That scared me away from using it but on this I had no better options...only pulled out one, out of like 50. Have to be strategic with stud placement too.
I'm getting kinda antsy to paint the cab and assemble my huge pile of parts, and then start on the box. I found some cracks in the fiberglass, guess I'll have to add fiberglass repairs to my arsenal of skills.
Junk Collector
Truck of Month
4,870
Rapid City SD
Made some progress, first off was removing 10 layers of paint from the cowl... NOT fun sanding in the vent openings. I did a lot of it with a wire wheel on a drill. I also patched in a piece to fix the missing section someone snipped out, presumably to gain access to the wiper linkage.
I finished sanding the rest of the truck and shot some etch primer, then found more places that needed filler. Fill, sand, fill, sand, repeat. Got it to where I felt pretty good about it and was able to pull it outside today and shoot the first coat of 2k primer on the cab. I noticed a couple things I missed and will have to go back to but this was a big step forward.
My roof repairs look pretty dang good, I think... not totally perfect but plenty good for my eye
Junk Collector
Truck of Month
4,870
Rapid City SD
I used some of this stuff to seal up the drip rails. It works REALLY well... it's self leveling so you have to dam up the ends with masking tape so that it stays in the ends and doesn't run out all over. Spendy at $50 for the applicator tool and $40 for the seam sealer itself but I have other vehicles that will need the drip rails sealed up so I think it'll be a worthwhile investment.
I will have to clean up the edges a little but it flowed into all the little gaps and stuff really well and filled it up exactly like I wanted it to.
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
That cab looks really good. Your work is pretty darn professional compared to some of the stuff I have seen done (or done myself).
I look at it this way, you are restoring your Ranger. You are not restoring a vintage Bugatti for Pebble Beach. I am pretty sure you are going to use this truck quite a bit. If you are happy with the work, then that is good enough.
Junk Collector
Truck of Month
4,870
Rapid City SD
Thank you!
Yeah, it's really just an old truck with a fair amount of things that will never be perfect. I am going to paint my Explorer and F150 so I figure this is kind of a practice run... I can learn a lot from this one and transfer those skills to others that (if I'm being honest) I am more interested in. It'll be fun to drive and look decent too.
BlackBII
Ranger Custom
Truck of Month
984
UT
Yeah man that cab looks great! Bodywork is tricky because when it's in bare metal and filler it's hard to see how the whole thing looks. Primer really helps you see if you did a good job or not. Have you used a guide coat and block sanded it?
Junk Collector
Truck of Month
4,870
Rapid City SD
No kidding! I missed a bunch of little dings and stuff, every time I prime something I'm seeing more. I used a black spray bomb primer guide coat on the back of the cab where I pulled a huge dent out, but otherwise I'm more or less going off of a couple coats of etch primer and then the first coat of 2k. I am block sanding between each with 320 on a 3M sponge pad and a stiffer Durablock for the big, flat spaces. I am getting better at finding low spots that way, I can see them where the block doesn't reach and is still orange peely. Wish I had those two blocks when I did the hood, it would have turned out a lot better, but live and learn. I think I'm going to need another gallon of base so I will for sure have a lot left over to redo it... or maybe find another hood...
