How to get leaf bolt out of shackle
booblinker
Richmond twp, mi
I am trying to get the bolt, that bolts the leaf to the shackle, out. Other then a press is there any easy way to get them out?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If they're rusted, good freakin' luck :rolleyes:
Only way you'll get them off is with a cutting disc on a die grinder or angle grinder (or what I did, grind out the rivets holding the brackets onto the frame, and pull the whole leafspring, hangers & everything off, and take it into the garage to give full assault to those bolts).
rickcdewitt
5
nor-cal
4-0 swap
the bolts probably rusted to the bushing sleeve,i cut the exposed ends off and got bolts from a truck that wasent rusty.
booblinker
Richmond twp, mi
I got it, just cut one side off, and burned the bushing out. Now i need to go find a shackle and bushings tomorrow.
projectnitemare
8
Osceola Mills, Pa
396W
That's pretty much what happens with all of them. Just did the shackles and bushings on a BII a few weeks ago.
Matt
gettle03FX4LevelII
Harrisburg PA
Ranger FX4 Leve
had to replace them on both of my 93's that i had.. actually my brother did it. it was the biggest pain in the ass because they are riveted to frame and you have to use an air chisel and a torch to get them off. Obviously we used grade 8 bolts to reinstall the new ones. The shackles were were like 80 bucks total for both sides for the upper and lowers. Yea he had to pretty much melt out the bushing on the leaf spring. He cursed me both times he had to do it. Good luck with it
King Crush
I had to get the bolts out when I swaped to SJ leafs. It was a bitch. They were all rusted in there and the nut is in the inside of it so you really use punch and hit it out with a hammer.
95XL
Fulton, NY
7.3L Diesel
An air chisel. Works wonders.
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
i just went through this myself, I wound up using a sawzall and cutting the bolts off.
When you put new bolts through the sleeves, load them up with anti-seize. If you ever have to remove them in the future, you'll thank yourself
