PMitchell08
- Mar 2, 2010
- 33
- Ohio
- Ford
- Engine Size
- 3.0L V6
I had a hard time with the scissor type disconnect tool as well (pictured below)I have that tool also from NAPA.
Even when I have it bottomed out on the hose nipple the fuel filter still will not budge.
No matter which tool I have used, I get it bottomed out within the nipple, the fuel filter will not come out.
Thanks for the input however.
I found that the plastic clip tools that nobody else seems to like actually worked much better for me. I like them because I can wrap my fingers around both sides of the line and pull much easier than the scissor type which put uneven pressure on the clip. I bought the kit sold at Autozone for $9.99
you can get them at this link:
[URL="http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp;jsessionid=10BD442E69F045DFF726EA9E8C0D4B89.diyprod4-b2c7?counter=2&categoryDisplayName=Tools&fromString=search&itemIdentifier=2356_0_0_&productId=2356&sortType=&parentId=6-10&filterByKeyWord=fuel+lilter+tool&categoryNValue=100006&navValue=101529&fromWhere=&itemId=1529-10&displayName=Line+Disconnect+Tool&store=4504&skuDisplayName=5/16,+3/8,+1/2,+5/8,+3/4+and+7/8+in.+A/C+and+fuel+line+disconnect+tool+set&brandName=OEM]Line Disconnect Tool[/URL]
Try turning the filter itself to be sure that it is free from the fuel lines at both ends and not corroded or rusted on. Also try a little WD-40 or PB Blaster in each end just to make it easier for the tool to slide under the line.
Hope this helps Good Luck!
