How to change throwout bearing
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
How the heck do you change the throwout bearing on a M50 slave cylinder?
I have the slave out and not sure on how to pull the bearing off.
pillen140
45
winston-salem, NC
Its one unit. Thats how mine came anyway.
pillen140
45
winston-salem, NC
P.s. I would change the whole slave anyway.... They are prone to failing.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
I have a fairly new slave with a broken bearing. Was wanting to just replace bearing if it could be done.
cocoasranger
5
south central Pa.
There is a snap ring holding the bearing on the slave, but I would do as pillen140 suggested and replace both. I had to drop the trans a second time trying to save a couple bucks and wish I had put in all new.:bawling::bawling:
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
If I recall correctly on the "Aluminum" 1988-92 slave it's a matter of squeezing the plastic retainer at two points to release plastic "Barbs" that hold the bearing retainer to the slave body.
On the 1993-up slave cylinder you depress the throwout bearing and remove the spiro-lok that holds the bearing on the "pilot"
I don't recall if there was a retaining ring on the '88-92 type or not...
as a note, the '88-92 T/O bearing is usually mounted on a BLACK plastic retainer.
The 1993-up is blue plastic, the two types are NOT interchangeable.
AD
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Cool thanks allanD I will just change both. I really dont' want to have to pull the tranny down the road. I can spend the extra money but would rather put that towards a new clutch or something needed more....
Roger
Tooele, UT
2.3
We changed just the bearing, now wish we'd changed the whole shebang...
escort_gts
16
Fort Wayne, IN
4.0, 5.0
well I have just bought a new slave. My luck it will go out as soon as I get the transmission put in.
kwikwitzkc
I have a new after market T/O brng. blk housing has (4) external barbs holding brng which must be released to install on slave, then brng can be put on and snapped back on barbs.
