how thick is the roof sheet-metal?
cammeddrz
23
Ford/chevy
efi 350vortec
i am planning on removing the cloth/foam headliner and replacing it with crinkle-finish black ABS sheeting. it will need either screws or rivets to hold it up. is the sheet-metal of the roof thick enough to drill holes in for rivets? or will the rivets poke out the top? i would like to know this before i take down (and likely destroy in the process) a perfectly good headliner just to find out it won't work
Its only about 1/32" thick. It's no thicker than any of the other sheet metal on the vehicle. In fact it's probably the thinnest piece of the vehicle since everything else has it folded somewhere.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
just plot and use the supports.
cammeddrz
23
Ford/chevy
efi 350vortec
i guess i should have re-worded the title to "is the Roof layered?" or is it just one layer? it sounds like its just one layer?
cammeddrz
23
Ford/chevy
efi 350vortec
where are the cross-braces? are there enough of them and are they placed so that i could rivet to them and be alright?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
remove the liner and get it awn self explanatory......or just strip the material and leave the board and carefully attatch to the board
cammeddrz
23
Ford/chevy
efi 350vortec
either of those were my original plan. i was just hoping that the roof was more than some 16ga sheet metal. either way i will make it work. i really want to remove the headliner entirely so that it tucks under the plastic trim pieces that go around the headliner. i'm sure the extra thickness will not stuff under there
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
why not just leave the bar metal? you could easily paint it to match the interior, or at least get close
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
cammeddrz
23
Ford/chevy
efi 350vortec
^^ oh yeah that will be plenty to work with
