How quick can you un-install TTB 1-2in leveling setup.
1994_4x4
Ohio
How quick can you un-install a TTB 1-2in leveling setup? (Where you just shim the coil) I apologize for this being a simple minded question. I was just wondering if anyone has got this down to a exact science. I'm planing on running small tires in the summer and 31's in the winter and was wondering how quick some of you can do this. (With tires already off and truck in air.)
UrbanRedneckKid
17
Cass Co, Missouri
5min per side.
Compress the caliper with a screwdriver.
Use the same screwdriver and hammer on the brake pins.
Rip off the lower shock nut with an impact.
Use a gearwrench on the spring nut.
4' prybar for manipulating and adjusting.
