How Much PSI
Davis
8
Long Beach, CA
Don't kill an svo for a ratty old ranger, even if it is a prerunner. Get the motor and tranny from a a turbocoupe or merkur.
A ranger 5-sp holds the power fine for a while, but the t-5 is SOOOO much more solid. I love my t-5.
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
A ranger t-5 holds the power fine for a while, but the t-5 is SOOOO much more solid. I love my t-5.
What issues did you run in to on your tranny swap? It's been so long I have forgotten.
James
Davis
8
Long Beach, CA
The shifter is exactly 9 inches father back.
The tranny crossmember needs to be moved forward a few inches.
The clutch slave cyl and hydraulic line are hard to find. I hear the 83 ranger hydraulic line is a much better fit than the 87-88 tc line (I know the tc line does not fit well).
You also need a TC clutch and maybe flywheel. I swapped mine out but I don't know if the flywheels are different.
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
Which ranger 5-spd are you talking about? There's quite a difference between the TK-5 (88 down) and M5OD (89+). Ther TK-5 is just a weak ranger transmission. The M5OD handles boosted 4.0Ls and pretty much has the same input torque rating as a standard T5. Plus if you get the 2.3 M5OD rebuilt with the 4.0L gear set, 1st gear is much nicer (numerically lower) for a turbo 2.3 than the T5's 1st gear.
skyy_4life
Brooklyn Ohio
2.3 turbo
yea im doing a v8 swap in an s10 right now and ran into the 350 sitting further back than v6 even with the v8 conversion mounts. lol. im not sure wut im going to do about it.
rurouni20xx
natchitoches, la
3.0L V6
efan on the s10 and make brackets that move the mounts forward, ive helped do a 350 in an s10. what tranny are you using? we blew the motor in the 350 (had bad rod and didnt know about it. bad crate motor...) and cut the front end and extended it out (lots of fiberglass...) and dropped in a twin turbo 502, that was kewl...
skyy_4life
Brooklyn Ohio
2.3 turbo
we got summit racing mounts and it works fine now we are finishing up last touches now.
Davis
8
Long Beach, CA
I'm talking about the M5OD. My 88 came with a M5OD and roller cam. I'm guessing it was a late 88. I just like the feel of the t-5 a whole lot more.
RacinNdrummin
7
Auburn, Wa
The T5 first gear in the 4 cyl tranny is just as good as the M5OD, and thats only with the 4cyl/small v6 tranny, the 4.0 gearset has a longer first gear. The T5 is a better tranny than any M5OD, the 4cyl T5 will handle more abuse than a 4.0 M5OD.
skyy_4life
Brooklyn Ohio
2.3 turbo
heh. finished the beast V8 "Super-10" and its amazing. ecspecially with open headers. heh.
Will
514
Gnaw Bone, Indiana
Toyota
I don't know much about strength but the M50D is a very clunky feeling transmission. It feels like a stick in a bucket of old bolts compared to almost anything else I've driven. I don't think it's weak. But it's not the feel I would like in a hotrod. It's a good feel for a truck.
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
They say the hurst shifter will do wonders for the M5OD's clunky feeling. It's supposed to shift like a BMW with the hurst on there.
As for strength, mine had 250,000 miles on it when I swapped engines and now has 15,000 miles of 300+ ft-lb turbo abuse. If and when it does break I'm gonna get a 2.3 case M5OD built with the 4.0 gearset.
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
My point exactly, you want a numerically lower (longer) 1st gear as the 2.3 turbo powers through 1st faster that you can shift. I forget where the numbers are now but I remember the 2.3 M5OD having a numerically lower 1st gear than a 2.3 T-5. The 4.0 M5OD definately has a numerically lower first gear than a 2.3 M5OD.
And I'd be interesting in seeing the design torque input rating (the value that the engineers who designed it used) for both the M5OD and T-5. I bet there's very little difference, if any at all. Obviously a world class T-5 is better, but since that's not what came behind the 2.3, I'm talking about the standard T-5.
'93BajaSport
Toyota
3.4
"World Class" T5s did come behind 2.3s. It was a global changeover after mid 1985. The 2.3 T5 was not rated as high as the V8 version because it had a shorter first gear.
