How much fluid for 8.8?
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I need to get gear oil for 8.8 28 spline. How much does it take? It has a Trickflow girdle on it.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Supposed to take 2.4L of gear oil in stock form, not too sure about with the trick flow cover. Probably holds more with it tho.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yea i'd say grab 3L
wizkid00104
13
2.3L/5.4L
Good call, I'll get 3 quarts and see where that gets me. 3L is just a little more than that. BTW, I like the metric system better anyways lol!
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yea, no quarts here in Canada eh :D
killacal
Randolph, MA
if that's a limited slip rearend make sure you put the friction modifier in the fluid.
wizkid00104
13
2.3L/5.4L
It is an Eaton Posi and I am using Lucas gear lube, which it says it is ok for LSD without extra modifier. Will this be OK?
killacal
Randolph, MA
I would contact eaton to make sure, but if it says that on the bottle I wouldn't be to concerned.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I would not be too worried about it. Worst case scenario is that the posi will grab better.
