How do i take off the emblems?
Disturbed_Ranger
Quebec, Montréal
Hey guys. I wan't to shave my truck. How do i take off the ranger emblems and the 4x4 and edge stickers? Can i do it without taking off some paint? My car is going for a compound on thursday so i wan't to do this before. Thanks for the help!
ranger1999 Bob
Brooklyn NY and a home in Deposit NY
with the metal looking ones you can take a thin wire or a single blade razor to them as close to the emblem as you can and then use paint thinner or goo gone to take the remaining gasket off the blue oval in the grille should bolt off or unclip and the stickers should peel off with some aftermarket sticker glue dissolver found at any auto parts store
blackdog89
pinson alabama
4 inch
fishing line and a good hair dryer or heat gun and goo begone works
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
no reason to be careful with the paint because it takes more than just removing the emblems to "shave" your truck as there are holes behind them.
Mac
183
C. Wisconsin
2000
199
I've used just rubbing alcohol and a hair dryer to soften it up and then just pry it off.
Dave
krugford
Iowa
Yep, there's gonna be two locating holes behind the emblem that are gonna need filled. Best way to do that is with a welder, which is gonna fry the paint. I wouldn't try just throwing putty or epoxy in there because it's not made to bridge gaps like that and it'll have very little to stick to anyways.
As for the stickers, I would try to just peel them off first. Sometimes they will come right off and sometimes they don't. If they don't try a little heat with a heat gun (be careful) or a hair dryer. Just don't get it too hot!
-krug
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
-krug
ya, the newer trucks also have a 1/2" hole behind the emblem, it has a lip so its probably for strength, but it would need a piece of metal welded in to fill it.
