How do I know how bad an engine is locked up?
Sigpros
13
Missouri
Back story. I just bought a 99 ranger with a 3.0 in it. 192k on it. The owner said his son was driving it and it quit and wouldn’t start. He took it to a shop and they said the motor was locked up. If you pull the dipstick the oil is old but not milky and radiator has coolant and so does the overflow tank. When you try and start it it just thuds. Is there anything I should try and see if we can free it up? Or lost cause? I bought the truck for a parts truck for my sons 97. He needs the bed and it has brand new tires and brakes all the way around plus a good radio and speakers and a new battery.
Sigpros
13
Missouri
This side looks wet. Didn’t know if it lost a head gasket or what? Not sure what 3.0 we have. And didn’t know if it was worth letting my son wrench on and see if he could get it going or not?
alwaysFlOoReD
5,156
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It could be a variety of reasons why it's locked up. I think it's a good learning opportunity if you and him have time.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
dizzz ahhh zzembowl
#5 is alive.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,596
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
3.0L are kinda known for the cam synchronizer locking up. This twists the oil pump driveshaft into two pieces and engine loses oil pressure.
If you think it's a head gasket... pull the plugs and see if it will turn over and push coolant from the cylinders.
But my guess is it lost oil pressure and locked up.
rusty ol ranger
2.9 Mafia-Don
7,717
Michigan
177 CID
.....and the 2.9 gets shit about head failure?!
alwaysFlOoReD
5,156
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
Pull off the belt and try and turn the crank bolt. If it turns over then one of the accessories are locked up.
